E-Clip insertion tool
  • E-Clip insertion tool
    Who has one, what does it look like, and how well does it work? An e-clip is an external retaining ring that snaps into a groove around a shaft and does not have the little holes that snap rings have for snap ring pliers. I went to my local "nuts and bolts" place and asked about e-clip insertion tools, to work with 1/8" and 3/16" and 1/4" shafts/e-clips. The e-clips are fairly inexpensive, but each different size requires a different size of insertion tool and they cost $57 each. Is the insertion tool something I could make, or does it have a tiny, tiny, slot that the e-clip fits into---if so I couldn't machine that.---Brian
    Sorry, it has to be made in a factory.
    -D
    DZER
      http://www.ebay.com/itm/NEIKO-E-clip...item2a4be2ff3a
        JRouche--That's a great price!! Unfortunately it doesn't do 1/8" and 3/16" shaft sizes.---Brian
          Would have suggested a tool made by Milbar, it's what I use, but they are out of biz. Thought about Jensen Tools, no good, they've been bought by Stanley.
          Did find this: http://www.duratrax.com/accessories/tools/dtxr1107.html but it's all metric.
            RoscoP---Yes, I found that tool as well, and it looks like it would be great, except for the fact that it is all metric. I have been searching for an hour and I can't find anyone who sells a tool like that in imperial fractional inch sizes.
              I have always used needle nose pliers, one size fits all
              Jon
                A hemostat works great and fits all the normal sizes. Thin the nose on a grinder if need be.
                RWO
                  I manage to loose 35mm circlips, e clips are making a nest somewhere, ping oh **** clips are the new official designation, they have other less eloquent names too
                  Mark
                    I guess I've always been lucky - no special tool required. But now I know, nothing will ever go on again. lol.
                      McMaster Carr has them for about $25. Like others I use needle nose pliers, most often I just put them on by hand. Modern clock movements use a lot of pretty small ones.
                        Here's a link to one similar to the one I use, mine is a Williams but I can't find anything by searching under the Williams brand.
                        I think Williams has been bought out by another tool company or folded.
                        http://www.ebay.com/itm/Jonard-CS-10...-/201161864184
                        THANX RICH
                        People say I'm getting crankier as I get older. That's not it. I just find I enjoy annoying people a lot more now. Especially younger people!!!
                          Brian,
                          After looking at the one linked by v860rich, I think you could make one out of some steel strapping. I'll leave the design to you.
                          Jim
                            Somewhere in my checkered past I saw such a tool, which appeared to be nothing more than a piece of nearly - flattened tubing, presumably with a rivet or weld or something to provide a stop at the appropriate depth, and attached to a short handle...
                              Brian before trying to insert the jesus clip (thats what we call them) put a small neodium (sp) magnet on it so when it slip's it won't go flying.
