anyone built a bench shear?
  • anyone built a bench shear?
    Need a small (12") shear for brass and copper. Anyone ever built one?
    Hi,
    No, but I've built a few 4' and 8' shears.
    How thick is your material?
    Dalee
      Originally posted by dalee100 View Post
      Hi,
      Dalee
      .040 and thinner
        Hi,
        You may want to consider a paper cutter like this. Cheap and easily available.
        http://www.amazon.com/Paper-Cutter-G...N%3DB001O3KMK0
        I have used such items to cut stainless steel shim stock up to .030" thick.
        Dalee
          There are usable 12" benchtop shears out there that will cut .025 brass or .040 aluminum.
          metalmagpie
            I bought a shear one day, either an 8 inch or 10 inch- don't recall now. I had in mind to modify it so it would work better, which I did and it does. It will cut a cigarette paper without folding, tearing, etc, .002 copper very cleanly, and 16 ga cuts beautifully as well. I actually bought it for cutting 16 ga stainless, which my other machine struggles with.
            Pretty sure I still have a few pix that can be viewed- a search should bring that up easily.
