I Don't Need No Stink'n CNC!...Drilling Jig
  • I Don't Need No Stink'n CNC!...Drilling Jig
    I make something called a "Cowboy Action Staging Strip"...It requires lots of properly spaced holes. I built a jig to do just that.
    Thought you might enjoy it:
    https://www.youtube.com/watch?v=u0an...ature=youtu.be
    You can read about the Staging Strips here:
    www.rvbprecision.com
    Nice Roy. Question...what do the aluminum strips pivot on? Is there a rod clear through?
    Jim
      Hi Jim,
      Yes. I drilled clear through with a very long. 1/8" drill and inserted a steel rod.
      I was drilling these holes using the DRO on the milling machine but it just took way to long and I need to make 200 of these things!
        You might consider using a forstner bit in place of the twist drill. It will produce a cleaner hole (and will eliminate the need for the aluminum plate).
        Hi, my name is Wilson and I am a tooloholic.
          Forstner bits are slow to drill. What he has there is a wood bit and probably as good as any. I would stack two and drill them together. Nice product in the end.
            The bit I'm using is a brad point, side cutting drill that I had to grind to change the diameter for a 45 Long Colt case. A Forstner bit would load up on this oak and be very slow and it would still blow out without the aluminum......I know because that was the first bit I tried...
              I'd put a spring arrangement in front to hold it against the back fence - as used in wood routing tables as it will be really annoying to sneeze and move the job a little at the critical moment.
              The right hand having to drop down and move the stops is very inefficient. How about moving the head down to give only 1/10 in clearance on the bit when up and using a bit of string down from the handle to a foot pedal.
              I know you're not in mass production, but it just must get very boring do if it takes too long.
                Nice jig for getting it done! Thanks for the video.
                  Nice jig, especially if the holes didn't have to be equally spaced. For equally spaced holes, the technique for used for making box/finger joints might be simpler. The gist is... imagine that instead of the aluminum stops, have one 'stop' located to the right of the drill bit. But instead of a stop, it is a rocker that drops a rod into the hole previously drilled. So to locate the next hole, shift the work to the right and drop the rod into the hole previously drilled.
                  http://www.sawdustmaking.com/Box%20J...xjointjig.html
                    VERY GOOD FOR "Mod 1" . Some of those ideas could be implemented for Mod 2. :-) At least that is the way I do for such jigs and fixtures. I really enjoy the fixture/jig design
                    a lot more than the use of same. :-)
                    ...lew...
                      A quick thought on technique, requiring a slight (I hope) mod of the fixture -
                      How about starting with all the flippers in the up position, riding on the back edge of the part? That way you could pull the part to the left, let the next finger drop down, butt up against it, drill and repeat. You'd be able to avoid a lot of movement that way, working one-handed on the part.
                      Frank Ford
                      HomeShopTech
                        Good one Frank. :-)
                        ..lew...
                          Fine way to do it, and probably a lot less spent than the $1500 Prototrak 2-axis CNC mill I got sitting here.
                            Frank, Great idea. I'm going to have to look into that as a modification. As far as the other Ideas I actually used the box joint technique on the table saw to cut the slots for the little aluminum stops.
                            And lastly, with a Bradpoint drillbit once the Bradpoint touches the wood it never moves out of position.
                              Works OK. Next time use a rail like you have. Put in a pin 1/2 size of the hole, drill and just lift the strip over the pin, push against the pin and drill, lift over and push and drill and so on. Tool building time 15 min.. From a tool and die maker.
