Why is there 12l14 and 12l15
  • Why is there 12l14 and 12l15
    Other than a slight difference in the carbon content that shouldn't really make that much difference why is there two different grades of free machining steel that are so close. Wouldn't one grade do it or is one better then the other for some things.
    Southwestern Ontario. Canada
    One probably heat treats better than the other.
      The carbon may be close but what of the rest, manganese chrome etc etc, there's probably a good reason, but what I don't have a clue, but whatever it is lives in the rest of the analysis
      Mark
        how does that stuff heat treat?
          http://www.matweb.com/search/DataShe...67c577d73df5fe
          http://www.matweb.com/search/datashe...a42655b94c5ad7
            I just did the MatWeb comparison thing for these two materials. Seems like other that a slight variance in carbon content and iron fe content they are virtually the same. Like Rustybolt, I suspect that one will heat treat better than the other.
            One of these days I will get my hands on some so I can try machining it.
            Tim
              I am not a metallurgist, but I do play one on TV.
              There is insufficient carbon content and lack of other alloy (manganese, here) to assist the carbon into lattice transformation to enable any value from heat treatment in the sense of increasing hardness.
              The lead that boosts machinability could be further detriment in that regard and renders unfit for welding.
              I'd happily be corrected if wrong.
                If it's anything like 12L14, it case hardens.
                  Agree with Carm, case hardening the only option for a low carbon steel. Bob.
                    It is a great metal to machine in either form, but I don't think the differences would ever matter in the kinds of things I make. I bought a mixed package of 12L14 from OnlineMetals but when I moved away from Puget Sound I mixed all the raw stock while shipping it and now I don't know my 1018 from my 12L14. I'll have to spark test it all
                      The leaded alloy or free machining steels don't have very good welding characteristics.
                      JL...................
                        You'll know when you machine it.
                          Rosco P nailed it in post #5. 12L15 has much higher yield strength than 12L14.
                            Both 12L14 and 12L15 are available in cold drawn and in hot rolled. Tensile strength is lower in the hot rolled version.
                            I still don't know why one would pick one over the other unless it is a cost thing.
                              Neither does the "12xx"
