110 volt Misting Pump
  • 110 volt Misting Pump
    Anyone know if a 110 volt pump similar to auto windsheild washer pump is avaliable,I am working on Drilling machine project and table has no coolant slots, so was wanting small volume pump for misting.
    No help w/the pump, but have you considered air drive?
      Nothing specific, but how about a modification to an airless paint sprayer?
      David Kaiser
      ― Robert A. Heinlein
        Start with the misting nozzle. Its requirements will determine the pump necessary (psi, volume, etc.)
          cheapy air brush gun HF about $5 need to do that myself. I used a chemical feed pump for years but finally died expensive but was free and can't replace.
          Ed
          Agua Dulce, So.California
          1950 F1 street rod
          1949 F1 stock V8 flathead
          1948 F6 350 chevy/rest stock, no dump bed
          1953 chevy 3100 AD for 85 S10 frame have a 4BT cummins motor, NV4500
          1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
            Hi would one of those injection pumps to inject the base of buildings with fluid as a damproof membrane.They may also be called dcp injection pumps My son has two of them,could I use one for this also?Alistair
              Try and get a Waterpik "dental cleaner." They have a small, adjustable stroke, positive displacement pump that will give the pressure needed for a mister nozzle. They show up at garage sales and "used stuff" stores and, since the unit never is/was actually in anyone's mouth, sanitation is not an issue.
              Duffy, Gatineau, Quebec
                Why not use a windshield washer pump and a stepdown transformer/rectifier? I did something similar as a coolant system for my lathe, see:
                http://mikesworkshop.weebly.com/cool...mp-system.html
                  Thanks for all info , just starting to gather the goods for another project.
                    One of these: http://www.kingfisheruk.com/item_20_dpc_injection_pump
                    Think it might be a little overkill for a coolant mister.
                      Not for bill gates its not. For him that is even an underperformance product and a compromise. Why not have the best?
                        Just out of curiosity why do you need a pump if you are going to use a mist spray? Meaning I am assuming you will be using compressed air to atomize the coolant.
                        If you are going to use compressed air then you could either utilize a venturi effect or pressurize the tank slightly to deliver the coolant to the nozzle tip.
                          Have you considered a making a fogbuster?
                          http://www.machinistblog.com/zero-fog-mister/
                          http://www.cnczone.com/forums/uncate...nt-mister.html
                          http://www.cnczone.com/forums/genera...-producer.html
                          I see Metalworking.com/dropbox site is under reconstruction?
                          Max.
                            I would like to pump coolant threw a fine nozzle:example(18ga. livestock needle without point) sorry for confusing this with misting.The Gang Drill project I am building ,table does not have coolant trough in it so that why am looking for low volume.
                              Max.
                              We just built one because we have flood coolant but it makes a big mess and mist fog is nasty. Our machinist wanted to use the flood coolant but now that he has seen it work he thinks we can do without it except for the very toughest jobs. I have one on my homebuilt CNC mill and just ran it steady for about 6 hours. Big pile of aluminum chips almost dry and no messe
