Hi everyone,
as my moniker implies i love to scrape metal!
What is metal scraping?
Simply put,
Metal scraping is a process of precisely removing metal from a surface needing a high degree of flatness, by means of hand tooling or machine driven scraping tools.
The scraped part is referenced to a known flat surface (i.e. a surface plate) and a spotting ink is used to determine the high spots.
The high spots are systematically brought to the same plane of contact.
When 2 scraped surfaces interface with each other, their friction is greatly reduced, especially with the introduction of oil.
The oil fills the low spots and provides a bearing surface, making the entire assembly float as if it were on glass. here's a picture of a scraped surface.
In this picture the blue spots are .0015" higher than the low spots!
Heres a link to my site for more examples!
if you have interest, i'd like to know!
thanks for reading!
Simply put,
thanks for reading!
