Husqvarna clutch thread
  • Husqvarna clutch thread
    The last hope, I just could not find it anywhere.
    For a project I need to know the thread inside the centrifugal clutch piece of Husqvarna chainsaw type 472.
    I believe it is metric and from ebay seller I know this:
    the threads measure 13.83mm (using a caliper to measure crankshaft thickness around the threads) and about 1mm center to center on the thread.
    Is it safe to assume it is M14x1 LH? I know for a fact that Husqvarna uses left hand threaded clutches.
    Anybody knows for sure?
    If you ever need to know, the small Husqvarna clutch - such as¨455 Rancher - has M10x1 LH thread and the big mount - such as 372XP - uses M14x1.25 LH thread.
    The useless information for today
      Just google what clutch puller they sell for that
        No puller for these, the come off with stopped piston and gentle tap via chisel.
