Ball turning jig
  • Ball turning jig
    Hi all.
    I have just made the Steve Bedairs type ball turning device, but i am having to scratch my head over the setting it up .
    If any one has one of these can you tell me the full set up info please, i need to know the tool post position in relation to the size of the ball to make ? thanks in addvance.
    CHUBBS.
    To generate a true spere, any ball turning device needs to meet these parameters:
    The tool tip is on spindle center.
    The radius is set to the diameter required; and/or the tool arrives at the final radius via articulation, usually by screw.
    If a close approximation is OK, use touch off. Turn the piece to req'd OD. Face the end. Move the tool towards the chuck the req'd OD, score a line.
    Set the ball turner pivot at spindle center, and mid-point of the length by swinging the tool from face to score line. Lock the carriage.
    Back off the cross slide and advance, whittling the ends off first.
      Thanks for the reply, i did in fact find a good write up on you tube this morning on the jig so all fixed now.
      Thanks again. Chubbs.
