For a project I am working on I need some "Timing " between components. If I have a disc with 15 evenly spaced holes arrayed around a circle and a second disc with 16 holes arrayed around the same diameter circle "How many combinations are possible?" If I am correct, there are 240 possibilities (15 x 16) or 1 degree 30 minutes (360/240). If that is correct, then 20 and 18 would yield 1 degree spacing.
Is there a flaw in my reasoning?
Thanks in advance
Pete
Thanks in advance
Pete
