grizzly/craftex 12x36 lathe feed & threading poster
  • grizzly/craftex 12x36 lathe feed & threading poster
    Hi all, this may be my first post but i have been lurking for quite awhile. I have a craftex 12x36 metal lathe with i believe is very similar to the grizzly. I got sick of always bending down or checking the side cover to view the feed speed and threading charts, so i made a spreadsheet for myself and printed it out at 11 x 17 then laminated it. This will be put on the wall behind my lathe for quick viewing. It took a long time to make so i thought id share for all to use if they can. If someone could verify that the grizzly chart is the same that would be great.
    Here is the spreadsheet published with google documents, i tried this originally but i cant figure out how to remove the boxes around the pictures i created, any help would be much appreciated.
    https://docs.google.com/spreadsheets...BCQVig/pubhtml
    I also have the threading charts made up and will post them if this proves to be of interest.
    Cheers, Jake.
