Double Headed Coin
  • Double Headed Coin
    A conversation at work led me to try to make a double headed coin for S&Gs. One of those things where I should've taken pics of the process but didn't.
    Anyhoo, my method was this, make a counter bored brass mandrel that a quarter just fits into for diameter and about half depth.
    Superglue a quarter into the mandrel, head side down.
    Counter bore the tails side off of the coin out to the flange to make a pocket until the nickel just witnesses through the copper core.
    wave a flame over the mandrel so the glue releases and coin can be removed.
    glue another coin on heads down and this time machine to remove the diameter so that it just inserts into the other half, taking some of the material away of the mandrel.
    Face off the tails side until all the nickel is gone and take a thin layer of brass. Again show it a flame to remove the glue.
    Glue the 2 halves together aligning the dates.
    It turned out OK but probably because it is 2 pieces it doesn't ring like a coin when flipped and even feels dud in comparison with a real one when handling it.
    Anybody else made them in the past and have any better methods to share?
    I think it was Mars-Red who posted pictures of a double sided coin a while back.
      S & Gs?
      George
        is it copper in there? can u solder them together? that would fill in the voids with material that will transfer the pitch..
          Yes, his thread "Magic!" back last December. One I remember well.
            It probably would be better to use a solder paste to join the halves. That would make it more solid. Apply the paste, cook it on 550 degree F for about three minutes in a toaster oven.
            Your machining sequence sounds good to me.
            Make it fit.
              Thanks for that Rich, his method of making the cover for the penny is pretty much what I did for one half of the quarter (an eighth I guess).
              I'll try again and solder it, good plan.
              S&Gs = ****s & Giggles which is all very well until someone giggles and ****s.
                Defacing of Govt. property is a no no!!!
                JL.................
                  JL.................
                  If its my money how can it be Govt. property? Oh, yea, right. Its never really my money. My bad!
                    JL.................
                    All you have to do is say it's art. There was no intent to defraud anyone...
                    oh wait a minute... double headed coin...
                    Yup, you're in trouble.
                    paul
                    paul
                    ARS W9PCS
                    Esto Vigilans
                    Remember, just because you can doesn't mean you should...
                    but you may have to
                      JL.................
                      Once upon a time, perhaps, when the coins were silver. No longer. Google is your friend.
                        It's never your money!!!!
                        JL..............
                          Originally posted by Georgineer View Post
                          S & Gs?
                          George
                          ****s and giggles
                          edit ... shlts and giggles
                          that was interesting how the forum anti swear-er caught my word and star'd it out
                          also interesting what is considered profanity now. On prime time tv they say quite a
                          few that use to be on the George Carlin list. If it can be said on prime time, it should be
                          able to be said on a forum. (humorous curiosity with some logic)
                          John Titor, when are you.
                            Here's one I made earlier
                            Machining sequence as the OP but I bored soft jaws to hold the coins.
                            Halves silver soldered together so it 'rings' when spun.
                            Over here the legislation re. coinage is 'blah blah blah ... with intent to defraud' being the important bit.
                            I waste a lot of time with coins as can be seen here.....
                            Mark
                            What you say & what people hear is not always the same thing.
                            www.remark.me.uk
                              Im impressed Mark, nice work. (on your page)
