I have a very basic question about dovetail cutters, I currently have none. I've noticed that build articles usually specify the width of cutter. 3/4" is a common recommendation for things like toolholders, sometimes larger.
So, How does the cutting height change as the width changes?
Catalogs don't seem to provide this info. A HSS cutters search on MSC gave the following info on the first item in the list.
Brand:Interstate, Price: $30.30 ea.
Included Angle ( ) 60
Cutting Diameter (Inch) 3/8
Cutting Diameter (Decimal Inch) 0.3750
Cutting Width (Inch) 3/16
Cutting Width (Decimal Inch) 0.1875
Material High Speed Steel
Shank Diameter (Inch) 3/8
Overall Length (Inch) 2-1/8
My MH 25th Ed. gives a 5/16" height for 3/4" & 9/16" for 1 3/8", and 2 larger cutters, but no formulas. Ok, so they cut higher as the cutter gets wider. Is there a rule-of-thumb that can be used to select the appropriate height when buying? I've also noticed the price can get steep when the diameter goes beyond 3/4".
I applied a little math and for the 3/4" cutter I get value of 0.3248 whereas MH says 0.3125. Must be a factor I'm missing? Just seems this would be a good thing to know, regardless the size of the project. I can see wanting to make items smaller than toolholders where a 3/4" would not work.
Just asking, thanks!
