Has anyone ever heated a piece of 6061 aluminum to expand for a shrink and use a retaining compound like Loctite 609? I have a steel tube approx. 1" diameter and 7/8" long that I need to "press" into a piece of 6061. The steel piece has a slight taper to it, I didn't make it and didn't realize it until after I already bored the hole in the aluminum. There is about a .0015 interference at the max but I would also like to put some retaining compound on this to make up for the taper on the end.
I could just press it in normally but I would prefer to heat the aluminum to expand it some but I don't know how the heat will react with the Loctite. Technical data on it says 300 degrees f but I assume that is for when cured. I am thinking that I would heat to aluminum block to no more than 300 degrees f for this. Does anyone have an experience with this?
