L-W dividing head... what did I just buy ???
  • #16
    Originally posted by mklotz View Post
    Beats the hell out of me! Complete brain fart! I apologize for the confusion. I've corrected the original post.
    Ahhh okay... its starting to make sense now
    Thanks
    • #17
      Does this help: http://wiki.vintagemachinery.org/Mil...ing-Heads.ashx
      or does it complicate matters.
      IMHO, you really want to fiddle or practice with the head so you get comfortable with tracking the number of turn/positioning, etc. Wouldn't want to ruin a 72 tooth gear after having cut most of the teeth because of a brain fart.
      • #18
        I agree..
        Im going to fool with making one of the smaller ones from scratch first. That way I wont be out anything other than a small piece of stock and minimal time.
        • #19
          Originally posted by Axkiker View Post
          I agree..
          Good idea, maybe made out of Aluminum or plastic... Is it missing one of the sector arms or is it just playing peekaboo?
          • #20
            So any ideas on the following.
            As you can see from the pic it didnt include a chuck and I dont plan on buying one any time soon. I checked fleabay and I can find #10 B&S dead centers with dogs attached but they are pretty pricey.
            I am considering either figuring out a way to use my r8 collets or making some sort of adapter for the spindle nose since its threaded.
            The spindle taper is what in my eyes sorta complicates things when considering the r8 option. The adapter for the spindle nose seems a bit easier as I could make all of it up then cut the 60 degree center using the mill with the adapter actually on the index...
            any thoughts
            • #21
              They are both there
              • #22
                All I can say is I hope you live many years to enjoy your new toy er I mean dividing head . LOL Have fun brother Alistair
                • #23
                  I still have the CNC program from when I made my own dividing plates - let me know if you need a set
                  • #24
                    the owner of the company was a very strange person, which he was alleged to be.
                    I tried to find something about this, I love to read about personalities in metal shop history and wish I new where to look to read about him, but the name L&W stands for two people I believe, maybe one died?
                    • #25
                      I do it a bit different than Marv and perhaps a bit easier to understand. No fractions!
                      You want 72 divisions.
                      You have 40 divisions on the screw, one per revolution.
                      You have 18 divisions on the plate, 18 holes in a revolution.
                      40 X 18 = 720 total divisions with the combinations of the screw and the 18 hole plate.
                      You want 72 divisions. 720 / 72 = 10. (If you don't come out even, you have the wrong hole circle.)
                      So to cut a 72 tooth gear with the 40:1 head and the 18 hole plate you advance 10 holes for each tooth. Easy Peasy!
                      If the number of holes you get with this procedure is more than the number on your hole circle, then you need to use one or more complete turns and then go for the remaining number of holes. So if you determine that you need to advance for 100 holes on a 30 hole circle plate, you would use three complete turns for 90 holes and then an additional 10 holes to come to the full 100.
                      Oh, and the divisions where I have marked that you can use "any" plate are the only ones where you rotate back to the same hole each time. This would be after one or more full rotations.
                      WOW you are a wealth of knowledge. I guess im still confused though which isnt surprising. So one of the gears I need to cut is a 72 tooth gear. I assume based on the chart you provided I would use the plate with an 18 hole pattern. Does this mean I spin the handle one full revolution and pin it in the original hole I selected???
                      Sorry still trying to figure all this out
                      Thanks
                      Make it fit.
                      • #26
                        PM sent
                        • #27
                          To the OP....Your internal spindle taper is most likely B&S #9
                          I used to have an L-W dividing Head, but sold it. Its a very nice & solid versatile dividing head. But I went over to the dark side. I now have a Hardinge dividing head. But anyway, I have numerous L-W dividing head documents in my webspace. In the link below over at practicalmachinst.com you can access links for them all.
                          Go down to the links in post #6:
                          http://www.practicalmachinist.com/vb...-parts-131285/
                          • #28
                            So why did you go with the hardinge??? Not doubting your decision just curious the differences ? I dont know much about this dividing head stuff
                            • #29
                              Maybe I am not measuring in the correct location but my spindle measures 1.250 + (big end) Wouldnt this be a BS #10
                              Also thanks for the links...
                              • #30
                                Another thing im curious about is it okay to take off the helical milling attachment. I dont have a mill that would even be able to attach to this so its only being used as a handle. I would rather remove and put in storage.
                                Any drawback from such ???
                                Thanks
