There's a nice article in Projects three about building a threading gearbox for a lathe. I have an 1885 F.E. Reed. I have only a few of the change gears. I'd like to retrofit it with such a grearbox. The lead screw on the Reed is 5 TPI. I'd need to establish a gear or chain and sprocket system that would allow me not to have to do the math to recalculate all the gears to match my leadscew. Any info out there?
An update on the Reed. I had to disassemble the headstock and clean out a handful of old, congealed grease. Now, the back gear works wonderfully. The industrial belt from McMaster-Carr for $40 is a wonder. Nylon cord imbedded in grabby rubber.
Soon to do sheet metal work. Gear shrouds and an electrics box.
May publish. Dunno.
May publish. Dunno.
