Originally posted by elf
View Post
I think the thing to remember here is that I don't think there is anything wrong with the spindle per-se, more just the spindle is under powered and impractical for the machines design and as you say, am probably abusing it. (Don't judge me) - Which I think you were right with earlier. I was looking at options and found the following speaking to a company that manufactures these spindles...
A 2.2kw, 24000rpm High speed 80mm chinese spindle at maximum power makes just under 3nm of torque at max RPM.
A High torque 2.2kw, 8000RPM spindle with a 3.7kw VFD will pull 6nm at max rpm. (DOUBLE!) So if your looking at getting a router (6090 etc) Folks... get that one!
He also suggested constant torque spindles arent as constant torque as they say they are but they aren't bad.
I have since found a 3.5kw high torque spindle that pulls 12nm of torque (Awesome!) and runs off a 5.5kw VFD.
Cost around 1200 dollars, and will mill alloy with proper hsm toolpaths and full DOC till the cows come home. (Moo.)
In the interim I would love to boost my available horsepower, but i'll look into the VFD errors or limits as you were suggesting.
