A friend of mine recently bought a small centerless grinder. The problem that he's running into is that he can't get anything to come out perfectly round unless the stock is perfectly round to start off with like a hardened and ground dowel pin. Anything else that he tries to grind actually come out what I believe you would call trilobular. If you mic it it will measure perfectly round because the lobes are spaced 120 degrees apart so you measuring from the high spot of a lobe to between the low spot of the other two lobes, but if you put it on a surface plate and roll it, it will roll back an forth, or if you spin it and indicate it with a dial it will show the highs and lows so it's not perfectly round.
I don't have any experience with centerless grinding but I remember hearing a long time ago that you need to use a 60 degree V in order to get the part to come out perfectly round. Perhaps some one can enlighten me.
I always thought that if a part is lobed it will just repeat in a centerless grinder, I would think it would need to be turned or ground on centers to be trued up and then centerless ground.
JL.................
JL.................
