Lubrication of the Harrison L5A lathe
  • Lubrication of the Harrison L5A lathe
    I've got a Harrison L5A lathe and they have a number of oil inserts for oil lubrication.
    Now, how do you get 30 weight oil into these fixtures? I've looked in all the machinery catalogues, and all I can find are greese guns. Thanks, John
    I use a good quality chainsaw grease gun.The type that is used to grease the nose of the bar.Works great.Just fill it with the oil you are going to use.
    e
    please visit my webpage:
    http://motorworks88.webs.com/
      John,
      You wanna Wanner!
      Best Oil gun ever made - Bar none! Problem is they're best ever price as well.
      RR
        Hi Martin good to have you back Bud regards. Alistair
          Hi Alistair,
          It's good to be back 'on-line'- nmissed all my machining mates over the last few months.
          What's all this about you and green paint then??
          RR
            John: for about $7 you can pick up the oil "gun" like Harrison ships with M300 (and probably others). It's about 7" long and develops pressure within a cylinder at the tip when hand pressed against the oil port.
            I picked up an identical copy at a nearby Stihl chainsaw and brush cutter dealer. I'm sure others must have it (maybe Euro brands).
            Alistair: I'm working on painting a green Harrison M300 and John S. referenced you (and paint) in another thread. If he has already harassed me, I didn't recognize it
            Den
