Whatsa difference between a 'planer mill' and a shaper? I've seen a planer mill before, but never in use. Does it use some form of rotary cutting action, or is it also a straight line motion like a shaper?
Basicly a shaper will use a single point cutting tool and the tool will move over the piece removing a chip on each stroke, the table, to which the workpiece is clamped or held in a vise, will index right or left, up or down "X" amount of thousandths between strokes.
A planer is much like a shaper only larger and the tool will be stationary except to index right, left, up or down while the table to which the workpiece is clamped will stroke repeatedly to and fro beneath the tool.
A planer mill is much like a planer except rotary milling tools are used instead of single point tooling.
