Hi All!
I was just about to order up a new Bison Set-Tru 5" (125mm) 6-jaw (2-piece) chuck for my Maximat V10P.... but I just discovered a very strange problem with this chuck in Bison's tech specs: You cannot chuck up a part that is between 43 and 50mm nor between 87 and 94mm with inside jaws.... Nor between 70 and 76mm with reversed jaws. Notice the gaps between D1, D2 and D3... and D4-D5. The jaw steps don't overlap. Their 6" (160mm) has a similar, but less severe problem (no dice between 64 and 67mm) -- and all larger chucks overlap just fine.
The solid-jaw version isn't much better. Buck's solid jaw 5" 6-jaw doesn't have this problem.... but they're made in Asia now... (and Kalamazoo has no 5").... [Addendum: My issue with Buck's move offshore is more about feeling sore for the gutting of North American manufacturing and the destruction of huge swaths of its economy -- not racism. Bison has always been Polish so, fair game.]
I'm disappointed; I thought I found a good solution for the broad range of work I do.
Does anyone run a 5" Bison 6-jaw? Have you noticed this? Do you chuck 44 or 88mm parts anyway without problems?
Thanks!
Thanks!
