I have a John Deer L120 mower. The wife started it without issue and drove it to the compressor so I could add air to the tires. She shut it off. When I was done inflating the tires, it would not start. Not a grind, not a click, not a whirrr. The headlights don't come on. Wholly inert. I put the battery on the charger and it seems to have a full charge.
Possibilities:
1. Corrosion on the battery terminals
2. A broken wire.
3. The keyswitch is worn out. (it includes the light switch) Even though the key is not reversible, I kinda noticed it goes in and turns either way.
4. Some safety mechanism has failed (though the last time this happened the mower would grind, there was simply no spark)
I found a fuse and examined it. Looks ok.
Ideas on how to troubleshoot?
Possibilities:
2. A broken wire.
