Forgot to post second bracket--Now things are out of sequence.--Oh well----Another one bites the dust!! I have one more bracket to build that doesn't fit against the curved surface of the milling machine. It is probably the most complex shape, but doesn't have to be fitted by trial and error to the cast mill surface.--And yes, after milling two brackets, I am finding those .0025" graduations to be just as hard as I had expected to work with. Its easy to take out the 1/8" increments, because they are one full dial turn. Then you have to divide whatever is left by .0025 and count graduations---and many of the graduations you want to hit fall somewhere between the graduation marks.--I did have a stroke of good luck, in that while rooting though my box of aluminum cut-offs I found sufficient stock to make all of the brackets.
