Originally posted by RB211
View Post
CX601 Milling Machine
And so, my friends, with the grace of God, the help of a neighbour, and lots of "huffery and puffery", the mill made it's way from my garage, through my office, and into my machine shop this morning. Nothing was dropped or broken, no fingers were crushed, and best of all, it fits into the hole in the wall I had prepared for it. Obviously, there will be some serious rearranging of the shop vac, belt sander, and chest of tooling drawers that were in there with the old smaller mill, but I will make that up as I go along. Thanks to everyone who has followed this long winded thread, and if anyone learned something on my journey, then that is the greatest reward of all. This thread is now ended.---Brian
Design engineer
Barrie, Ontario, Canada
Now for the reason I had the mill apart. I was doing a quick job yesterday and noticed after chucking an end mill into the collet that there was a crack in the collar of the spindle. I have no idea how long it has been there, nor what may have led to this. I tore it apart yesterday afternoon, and popped over to Busy Bee to see what a replacement would be to get in. I feared the worst and was imagining ways to repair it, but was surprised to find they had two in stock at the warehouse and could have it to me in a couple weeks for $119 and tax. Not too bad, but it raised the question why they are stocking these. I wonder if this has been a common issue, or are they just trying to do a better job of keeping repair parts for the machines they are selling.
The crack extends up all the way into the bearing area of the spindle. It closes up and is hard to spot when the collet is removed, so for the photos I chucked one up to make it show up better. Also, while I have it apart, I think I will "forget" to reinstall the locating pin in the spindle which is actually just a screw with a turned end on it the protrudes into the collet bore.
Originally posted by EddyCurr View PostInspect for presence of stress risers.
Originally posted by malbenbut View PostShrink a sleeve onto it, it will be ok
MBB
Never mind fixing the old one. I'd be shrink fitting a sleeve onto the new one so this doesn't occur all over again.
As he says it only needs to be around a 1/8 wall thickness. But I'd suggest you locate something that has a higher yield point for making the sleeve than mild steel. A good higher tensile value steel would only need to be around a 1/8 wall thickness to hold the spindle together.Chilliwack BC, Canada
Originally posted by BMW Rider View PostI was doing a quick job yesterday and noticed after chucking an end mill into the collet that there was a crack in the collar of the spindle.
The crack extends up all the way into the bearing area of the spindle. ... Also, while I have it apart, I think I will "forget" to reinstall the locating pin in the spindle which is actually just a screw with a turned end on it the protrudes into the collet bore.
The locating pin/screw mounts in a hole drilled in through the side
of the spindle. Where is that hole located circumferentially, relative
to this crack? If situated 180؛ across from the crack, this would be
a curious matter.
