The machine I looked at appeared to have a hole
in the side of the larger dia segment at the end of
the spindle that has the female taper for the R8 collet
where yours is cracked. Visible when the spindle is
fully up.
Your photo corrects my erroneous impression that I was
looking at the hole for the pin - your pin is higher, up
above the bearing inside the quill where it is unlikely
to be seen at a casual glance.
Still, there was a hole in the lower section. When I
posted earlier, I was musing about the possibility of a
pin in this lower location being inset so far as to create
a sidethrust on a collet as the collet was pulled up into
its seat.
fully up.
its seat.
