Grit for grinding end mills
  • Grit for grinding end mills
    Is 100 grit too course for grinding end mills? I can get the exact wheel I need from shars for about $50 but it's only avaliable in 100 grit which seems a bit course to me, but then I don't know for sure. I can easily find wheels for Darex, etc but these are well over $400 and I can't justify that much expense for a wheel for my needs, at least not if I can get something cheaper to work.
    Quite the opposite, IMHO. I wouldn't go any finer than an 80, and would likely get better results with a 60.
    What is the O.D., width, I.D. and shape designation of the wheel you need? What grinder do you have?
      Do you plan on grinding the ends only or the diameters too? What machine are you going to use: T&C grinder, surface grinder with an air bearing,...? Are you buying a CBN, diamond or AO wheel?
      WI/IL border, USA
