Pro and cons of treadmill motors etc.
  • Pro and cons of treadmill motors etc.
    I'm working on the design of my CNC mill. Iv'e been looking at surplus treadmill motors to power the spindle. They look like a good deal and I am looking for high RPM which they have. I have never played with one so what should I be aware of when looking for one? Any one know what sort of speed control the treadmills use? I would build a PWM controller if I must.
    Next question. How much of a mill table can you move with a NEMA 23 stepper with 280 in/oz of torque and a chopper controller? Anyone familiar with this controller and the outfit selling them? Also looks like a good deal.
    http://www.tecel.com/st200/
    I found a guy in WA selling new NEMA23 280 in/oz motors with double shafts and encoders for $45 USD. Also seems like a good deal. Some very good prices on NEMA34 motors too.
    http://www.seanet.com/~dmauch/
    Anyone deal with him?
    One of the best groups for this type of info is...
    http://groups.yahoo.com/group/CAD_CAM_EDM_DRO/
    Great bunch of guys with tons of knowledge.
    I remember there was a discussion on treadmill motors, can't remember the result.
    Tom M.
      Evan,
      Dan is a good guy to deal with. You won't have any problems and those motors are a steal.
      John S.
        The treadmill motors I have several of,I should have bought more when they were cheap.I got one that came with a full blown SCR controller for $50.00,works great,I have another that I used for the welding positioner at work that I used just a variac and a full wave bridge for,it too works good,but more primative.
        They are pm motors,so a person of your skills could easily build a controller.Mine have a 17mm straight shaft and a 14 mm left hand double start threaded end(guess what got cut off)I took it apart and turned the shaft 5/8" with a 3/16 keyway.They use a ball bearing on both ends,mine came with a stub stuck on the brush end of the motor,I beleive it was 5/16"x 3/4" long,I assumed this is for a cooling fan,and judging from the amp ratings([email protected])it needs it.
        All in all they are great little motors and used to be cheap($12.95)until everybody caught on.They really excell at providing lots of power in a small package.
        I did mount a small plastic fan blade and made a shroud out of a pvc cap,I also used a piece of furnace filter on the business end to keep the errant chip or two from getting in(the motors are open end for end).
          The 2hp motors, there is one spot in Canada that sells them for 24.95 american money..
          There is one guy on ebay been reselling them for $50 a pop.. I hear tell he is in a wheelchair and made 100k last year.
          About $30 is a good price. They are mostly not a 1.0 duty factor motor. Meaning don't run them at full nameplate power too long.
          My old craftsman table top drill press was acting up today, I may be looking for a similar motor. I ran it as a cnc for about a year. Meaning it ran most the time.
          Check ebay for battlebots the PWM controllers on there, you can't build one so cheap, already on a huge heat sink..
          Seems like mach2 can output a pwm for spindle speed control.
          David
          [This message has been edited by ibewgypsie (edited 06-16-2004).]
