Okay, in my other thread I was able to trade for a much needed 4 jaw chuck, and also found a supplier for a backing plate..
I have also been kicking around the idea of just making a back plate as I have found I can get the materials from speedy metals for roughly 1/2 the cost. Im not dead set on the idea, but it makes for an interesting idea none the less.
While examining my chuck, I noticed something I found odd. The inner register is not a 90 degree shoulder I expected. While thinking about all this I figured I would make the backing plate in 2 pieces. 1st, the main hub which would have the spindle (L00) taper and locking nut threads. 2nd, the actual backing plate which the hub would be press fit into.
As far as the through hole bolts go I figured I could use that inner register within the chuck body to mount the plate center. Then by having everything true center per that register I could transfer punch then drill and tap.
Is there a reason that register is not a 90 degree shoulder and is tapered ???This is a 4 jaw independent chuck so its not like there is through bolt adjustability like a buck.
Confused.
[IMG]
[/IMG]
Confused.
[IMG]
