I have some SMA connectors that I have to put on RG-174 coax. The ferrules require a hex type crimp. I don't have the crimping tool so I was going to make a small hex crimp die. It should be fairly easy to do. Mill the slot to the proper depth and width cut the angles on the sides and then cut the piece in half. When you put the two pieces together you have a hex hole, that's my crimp die.
What I need to know is the proper size. The ferrules measure .158 on the OD. I found some crimping tools that have the size for crimping 174 and it's .128 for the die. The question is, is that measured between the flat sides or corner to corner. I'm guessing it's like measuring hex stock or if you were to draw it you would draw a .128 dia. circle and divide the sides x 6. I don't want to play hit and miss.
JL................
JL................
