LED Tube Shop Lights?
  • LED Tube Shop Lights?
    I saw some during my lunch break. I need to replace my $10 fluorescent shop light fixtures that are ancient. These are about $38 for the 2 tube shop lights.
    What do you think? Any big negatives?
    Decent LED's are a definite step up from fluorescents in the sense that they require little to no maintenance.
    Also your existing fixtures can be converted to LED if you are motivated. I've been converting mine over as the fluorescents fail. I seem to recall that I paid about $9 per tube on the 'bay, that was over a year ago.
      A friend who's in maint. just replaced there t12 lights with square housing LED lights he said the housings are about 2' square, and they are so bright you can't look at them directly, and they are ceiling mounted about 24' up. they only have a small square LED in the middle, with a pyramid shaped reflector.
        I have similar type security lights, what used to be a 500w halogen light has now been replaced with a 20w LED with no loss of light.
        Paul
          How low of a ceiling height is acceptable with these LED fixtures?
          Will it give headaches to people with lighter colored eyes?
          Noise issues?
          Cold weather issues?
            I bought a 2-pack and tried them. They were so much better than the fluorescents that I bought 4 more packs and did the whole shop. Had one go bad after a month but the others are holding steady. No mods to the fixtures and no cold start issues, full brightness instantly. The color doesn't bother me, either.
              Where did you buy yours from, if I may ask? I have been thinking of doing this as well as I am pretty sick of dealing with the fluorescent tubes, disposal hassles, etc. I'd like to change all of mine, but have quite a few tubes in total. If they are decent I'll just get a few and use them as the tubes fail.
              Did you get the "cool white" or "daylight" flavor?
              Thanks!
                I just installed two of these and I'm pleased. https://www.earthled.com/products/lu...ant=2403570948
                Just waiting a bit to see if any smoke escapes before ordering more but they are bright and doing the job.
                Len
                  I got them at Costco, and they're the cool white (4100K) version.
                    I replaced the fluorescent light over my work bench with an LED shop light from Sam's Club. I can actually see what I'm doing now. It's completely silent, but had to tilt it slightly to keep it from blinding when looking up at the shelf above the bench.
                    Lewis Grizzard
                      I'll second what everyone else said. I needed a shop light fixture over my lathe, and thought I was going to get a fluorescent one until the LEDs caught my eye. Half the number of bulbs give more than the same light output, and if the published life expectancy is to be believed, they should last me about 25-30 years before needing to be replaced. The light is bright, clear, and easy on the eyes, there are no noises and they don't take time to warm up. I haven't noticed any drawbacks so far.
                      Max
                      http://joyofprecision.com/
                        So, it seems we're talking about two things here; LED bulbs that directly replace T12 tubes, and LED specific fixtures?
                        If direct tube replacements, are changes needed to the fixture? Like removing the ballast? Or do these tube just go in?
                        I have the same issues with the tubes; constantly changing, low temps, etc. and would love to go LED for the big
                        lights. Already have LED task lights on tools.
                        Thanks,
                        Pete
                        1973 SB 10K .
                        BenchMaster mill.
                          Thanks,
                          Pete
                          The ones I'm looking at are also at COSTCO. They have the LED fixtures with tubes and they have LED replacements for fluorescent tubes. The replacements don't require changes to the fluorescent fixtures according to the box.
                          The box says the LED tubes have a life expectancy of 50 years. I'd be happy with half that.
                          COSTCO has one fixture plugged in to try. Looked good. Pull chain switch.
                            Not really a shop issue, but is there a UV problem with the LED tubes?
                            Gronk
                              One issue I noticed is that, although the bulb are compatible with existing fluorescent fixtures, some fixtures will not work with only one bulb in them. Two bulbs in a 4 foot fixture is a bit bright, but not a big problem for the ones up on the ceiling. Over the bench and machines it was too bright. I had a mix of fixtures and managed to get everything worked out. As for UV, it will probably be much the same as it was with the old fluorescent bulbs.
