Home made steady
  • Home made steady
    I was clearing out pics on my iPad and saw these .Its been a while since I built it and couldn't recall if I posted anything on here.I did a search and didn't see anything so thought I would share.
    I didn't really do a lot of building pics but just a few at different stages.
    This steady was for my monarch lathe.the cost was too high to purchase one so I decided to build it.I wanted it to look somewhat like it belonged on the lathe so that's why it is shaped as it is.
    I started out with a flat plate. Radius end it and drilled the center hole.i have 3 of these plates for making these..Its sat around a while.lol
    I didn't have pics of the arms of the steady but you can use your imagination.lol
    I set it up on the rotary table and drilled and bored the holes for the fingers.
    After that was don I sawed it in half and made a hinge and bronze bushings for the fingers.There isn't any pics of this work.Also made fingers and knobs.
    Also made the base that fits the bed but again I didn't take pics. I really don't think much about following the build with pics at every step.Maybe I'll change that so I may give others ideas or such.I'm not a great teacher
    Happy with how it functions and looks. Jim
    Pic limit..Finished pics
      BINGO, we have a WINNER.
        Beautiful job! Probably better than the original.
          Wow! Beautiful work. You took care with your design and execution to make your weldment joints bland in clean and smooth as a casting. That is a real plus considering most such executions while functional stop as rough welded unpainted plate.
            Thanks guys.i should have matched the knobs to the machine but got lazy..
              Been me I would have changed the machine knobs to match the steady, far better and functional.
                Hey nice job. I may have to do the same but at the moment whilst I don't have the requirement I'll keep searching for one or the steel that was a hell of a chunk you used
                  How did you do the outer radius on the steady,is it machined or done on a belt sander?
                    Yeah, it looks like crap.
                    You should send it to me for proper disposal and make yourself a decent one.
                      rotary table. saw cut to scribed line then milled it.
                        very nice, looks like a Monarch quality creation.
                          Nice trick with the roller lifters!
                            WOW! Nice job! Probably better than factory.
                            My buddy George & I were visiting another metal trader who we know just made a several Atlas & other machine buy & of course had to look in his metal can like a couple of hobos & George picked up a good sized spanner which I said "that will fit my Pacemaker" Sure enough perfect fit for the chuck!
                              Gee and I was impressed with your other steady when I saw it in the Shop made Tools thread a while back.
                              Jim's pics start at post 1465 and carry on and off to the next page.
                              http://bbs.homeshopmachinist.net/thr...-Tools/page147
                              Now you show us even more tool porn...this one is absolutely beautiful. Thanks for posting these.
                              To add insult to injury I now see you have not one but two Monarchs!
                              Have you no shame?
