drill press columns- useful to re-purpose?
  • drill press columns- useful to re-purpose?
    Title says it all. For some reason today I was thinking about cast steel vs cast iron- then it occurred to me that drill press columns are a cast product (every one that I've seen anyway), and are machined on the outside. That should make them a good starting point for a project of some kind- sleeve for a spindle perhaps, or maybe the spindle itself depending on the diameter. Having had a need for a large through-hole spindle at times, I've entertained the idea of making one, and the idea of using pipe usually throws me off because of the weld seam for one, and the lack of precision in the fabricating of it for another. Who knows- maybe a drill press column could be a good starting material.
    Other things like this are the tubes you find on power feed assemblies for wood shapers, etc.
    I have seen lathes using a round tube for a bed, mostly wood lathes, but still it's a machined piece where the OD is 'ready to go'. Thoughts?
    Just WHERE does one find "spare" drill press columns? OTOH, Durabar sells hollow cast, either grey or ductile. What size would you like?
    Duffy, Gatineau, Quebec
      There is such a thing as "DOM" tube (Drawn over mandrel) which is smooth and available in different steel alloys. Probably much more suitable for a lot of uses, and in the US is available from mcMaster, Online Metals, Speedy Metals, etc, etc. Surely you have some equivalent source up there.
        I am selling one at the Kernville airport annual mens only swap meet tomorrow. Come on by, it starts at six. Hot dogs .50$ soft drinks ,the same.
        It is a stripped camel back, no gears, no spindle. Has a good column and the table slides on the column.
        No girl stuff allowed for sale!
          darryl, knuckle head. Case Iron posts are larger I think, for the mass. sOLLY again, i dont read much. I am so slow..... I am prolly way behind the discussion-. JR
            I see these things at flea markets and yard sales from time to time. Usually the 'entry level' type of dp, complete with sloppy quill, no table height crank, motor missing, etc, going cheap. I do have a source for DOM but it's $$$ here.
              A slip roll!
                Originally posted by vpt View Post
                A slip roll!
                Andy you keep quiet until you build the thing. No more posting in any threads until you at least can post some progress pictures. Now shut up and get busy.
