Horizontel Band Saw Blade Question
  • Horizontel Band Saw Blade Question
    Will a bymetal saw blade last twice as long ( or longer )then a carbon steel blade
    Not if all the teeth get ripped of while trying to cut something too thin, too hard, or just jumps out of the vise.
    Bi-metal shines in predictable condition. Not really worth the money in the HS where the need is cut such a variety of materials.
    When is the last time you just "wore out" a saw blade? More common is to destroy the teeth on one side or the other.
      Yep. Properly used a quality bi-metal will easily outlast carbon. The initial cost is higher but the total cost of ownership
      is much lower.
      Pete
      1973 SB 10K .
      BenchMaster mill.
        As CalM said, how often are bandsaws used properly.
          I bean buying the olson blades i do a lot of cutting with my horizontel band saw . Yes the blade does get dull. I mostly cut 1018 or 1020 2 1/2 dia. mild steel. Just ordred new blades today and was thinking i maybe should have switched to bymeetal blades witch i never used in my saw bevore to get a longer live of the blade.
          Thanks for the imput
            I have found in my saws the bi-metal blades last 3-5 times longer. I use my equipment properly and take care of it. No blade will go very long with misuse and abuse.
              If you try a good bi-metal, variable pitch blade you'll never go back.
                What brand do you recomend
                  I use Lenox Diemaster 2. Superb.
                  Most of mine come from here http://www.bandsawbladesdirect.com/b...and-saw-blades
                    I use Morse. There's a good 'web' price from Enco all the time for my size. (Old Taiwanese 4X6) I really like the 10-14 variable pitch, as it does a good job on a wide range of materials and thicknesses.
                      Lennox Diemaster II is my blade of choice, abused or not. I can get 6 months out of one if I'm careful, but I have a hard time getting a week from a carbon blade. It ain't anywhere near worth using them.
                        Bi Metal blades are the only way to go. What size saw do you have? I have some bi-metal blades for a 4X6 saw that I sold. I'd make you a fair deal on them.
                          I just ordred 2 olson carbon steel blades $ 21.50 bevore i started asking for opinions. If i am lucky 1 will last 1 month but i better use cutting fluid on each cut. The next time it will be bymeatal blades.
                            I buy from Sawblade.com,we use their M42 bimetal blades at work.We cut tons of metal per month,mostly structural,but also stainless,aluminum and copper.We average 2 months or better out of a blade running coolant.
                            https://www.sawblade.com/order-601-s...altbar-m42.cfm
                            (if you order from them,put "no calls please" in the comments box,otherwise they will bug you)
                            Bimetal blades do have a break in period as well,we run ours at the lowest feed rate for 3-4 hours before turning up the feed.
                              Thanks wierdscience
