14' Rockford Lathe Parts
  • 14' Rockford Lathe Parts
    Are there used gears to be had for a 14" Rockford ( 1920 ) lathe to be had
    Which gears?
    allan
      According to this it uses a Norton gearbox which other lathes used so maybe search for Norton gears may turn up what you need easier than searching Rockford.
      http://www.lathes.co.uk/rockford/page3.html Check out this restoration http://www.lathes.co.uk/rockford/page4.html
        Originally posted by kitno455 View Post
        Which gears?
        allan
        This is a friends lathe he need the bull gear on the back gear and the gear on the head stock
          Chances are, most of those gears are standard DP, probably 14.5 PA. You might get lucky and find some off the shelf gears that could be adapted.
          allan
            Thanks kitno
            There are some on e-bay that may work. After looking at the lathe yesterday i fund he needs all of the gears on the top end
            some one before him relay abused this machine. He paid $ 100.00 for the lathe without all the attachments he thought he got a deal but now he finds out the hard way like a new chuck he paid over 400.00
