We need to replace a line post on a six-foot tall chain link fence with one that's a larger diameter. The new post will extend above the top rail, so a short section will have to be removed so we can install caps and strap clamps on each side of the new post. The new post is going in the middle of a twenty-foot section of fence. The new post is necessary to hold the rollers for a cantilevered gate.
The top rail appears to be in quite a lot of compression from the tension of the fence fabric. How should I go about cutting the top rail? Should I weld a brace around the section that's going to be removed before I make the cuts, or just remove the clamps on one end to take the tension off the fence fabric?
The other option is to fabricate some brackets to hold the rollers to the existing post. That approach would avoid cutting the top rail and replacing the post, but it wouldn't look as neat as having a new post of the correct size.
The existing post is 2 3/8" diameter, and the new post is 4". The rollers are only made to fit a 4" post. The upper bracket would have to extend above the top rail, but that's not much of a problem to do.
