I recently purchased a used 6 1/2"PRATT-BERNERD IRON BODY 4 JAW INDEPENDENT LATHE CHUCK.
I am hesant about grinding the jaws because I tried on a cheap 3 jaw and couldn't get it rite.
The outer gripping surface has more taken off than intended, it didn't fix the runout. I made a plate so the jaws were under the same pressure as gripping.
I used a high end flex shaft for the grinding mounted on the tool post.
What'd I do wrong?
What'd I do wrong?
