FrogLube
  • FrogLube
    Anyone tried using FrogLube on micrometers etc. I was at a gun show today and ended up buying a bottle of the stuff. Based on what they say it seems like a good candidate for corrosion resistance and lubrication of measuring instruments.
    Just curious if anyone was using it or had any thoughts. Worst case I give it to a friend who has lots of guns.
    Never heard of it before but after looking at the web site and seeing:
    FrogLube is the only firearms care products company that uses exclusively bio-based and food grade ingredients to meet existing firearms operating and care requirements.
    I would personally not use it as I like my lubricants to be non-biodegradeable and last a while. Probably why I skipped using butter on my AR-15.
      The deal is that mineral oils are "saturated", they have no "double bonds" which can allow the molecules to link together and "gum up". They also are not subject to spontaneous combustion in normal circumstances.
      Double bonds are a weak spot, they are unstable and will break and bond to some other atom fairly easily. A lot of bio-oils both vegetable and animal, DO have such double bonds, and so they WILL "gum up", at least if un-treated. Plus, they *may* be subject to spontaneous combustion, due to the energy released when the double bonds break and form a more solid bond.
      Overall, with no further information, I'd not get into that stuff. Odds are they have dealt with the potential issues, but I'd like to know that positively before using them.
      Also would like to know what other "food grade" materials may be in them. Some may have undesirable features or factors.
      Maybe it's the equivalent of BrylCreme for frog hair
        Do you buy it or just throw some toads and a LB. of lard into a blender.
        Southwestern Ontario. Canada
          Be aware it's an organic product & will spoil. I bought a can of the paste & haven't opened it after the friend that recomended it said it went rancid on his guns.
            it is rebadged Soy Lube 100.
              I bet Soy Lube 100 is cheaper.
                yes it is, about 1/3 the price of Frog lube.
                  Another VERY well known "bio-lubricant" is Snake Oil!
                  Duffy, Gatineau, Quebec
                    Tried Frog Lube on several firearms , Over time it will gum-up the moving parts. I put it on the didn't work list.
                    Definition: Boat, a hole in the water you throw money into!
                      It should be called FishLube...
