starrett oil harding steel how to mill
  • starrett oil harding steel how to mill
    does it machine just like other steel I have never machine it what should I look for ie speed for 1/2 in. thanks
    Hi,
    Yep, it will machine well. I use cutting speed of 80fps to 90fps depending on the size and power of the machine I'm running.
    Dalee
      Originally posted by dalee100 View Post
      Hi,
      Dalee
      Is that right? fps? Not fpm?
      'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
        Yeah, that mistake seems to be gaining in popularity here. I've noticed it several times recently.
        That's the problem with writing laxity, bad grammar, poor spelling, etc., mistakes multiply like rabbits.
        .... or maybe fps was intended but the quantity was off by a factor of 60.
        Lynn (Huntsville, AL)
          Use carbide mills and it's all good
            It's high speed machining, brough.
            You cut it so fast, the chips don't even
            land on the machine table. That is how
            to roll.
            --Doozer
            DZER
              I think he meant 80-90 SFM, SFM meaning surface feet per minute. With hss tooling that would be about right.
              RPM=SFM*3.82/cutter dia
              611.2=80*3.82/.50. Might be a little too fast on a manual mill.
              Sent from my SM-P900 using Tapatalk
