Mystery metal post - what is it?
  • Mystery metal post - what is it?
    I also found this among the metal that was being scrapped. It is made of steel, painted green, and has two rows of short carriage bolts fastening a piece of channel inside a larger channel that is welded to a bottom plate, with mounting holes. The inner channel has square holes for the carriage bolts. There is also a piece of steel tube that hinges on a bolt, and it looks like a short boom. Seems like some sort of jack or adjustable support. Any idea what it is? Or what I might be able to use it for?
    USA Maryland 21030
    I can't see enough of the gadget to verify my hunch, but one clue might be laying on the ground in the bottom right of your picture -- the fencepost pounder.
    Is there a way your gadget could hook onto a fencepost to pull it out of the ground?
      Looks like some sort of road barrier post, like the wire rope kind, just guessing
      Mark
        Adjustable shelf bracket perhaps? Mounts horizontal on a wall? Just a SWAG...
        Sole proprietor of Acme Buggy Whips Ltd.
        Specialty products for beating dead horses.
          Maybe part of the adjustable height leg assembly for a roller conveyor.
          Or since it was found in the dumpster, maybe just a piece of crap that should have stayed where it was.
            One of the first things oft suggested in a mystery metal post is a spark test.
              Rosco-P got it. I had a friend that used to sell conveyor systems. He brought me some that they had scrapped. I used it for all sorts of projects.
              Hi, my name is Wilson and I am a tooloholic.
                Pallet rack?
                -Doozer
                DZER
                  Being a roll formed product any of the suggestions is likely, anywhere a high volume is required. Last I priced roll formed versus press bent the minimum footage was 5,000 plus development cost, but very competitive if amortized over thousands of feet.
                    Those nuts and bolts are like new!
                      Today I looked closely at this thing and on the base is stamped "PEGG-LEGGS". I searched for that and found a site with a reference to "www.peggleggs.com" but it's not a valid link. However, I found something else that seems pretty close, which is a pallet rack repair device:
                      http://www.mh-partners.com/web-damotech.htm
                      Watch the video
                      USA Maryland 21030
