cutting a drive worm gear on a lathe
  • #16
    So far we don't have enough info to actually help the guy...
    allan
    • #17
      I havnt recieved the gear yet so i cannot give to the specs on the gear.. :/
      • #18
        Originally posted by Mcgyver View Post
        we've been told its multi start and a largish DP?
        I had asked if there were more than one. If they aren't timed exactly right, there will be a slight pause as the next "tooth" comes into play. If it were for a lathe, it would produce rings in the finish.
        • #19
          there is only one gear to make the other one is perfectly fine idk how only one goes bad there might be a gremlin hidden that caused it to fail.
