in the 40's when i first got interested, an awful ot of jobs were h/spaced w/ cartridges..some 3006 ga. around, not much else, .....100 cases were slected ( would generally last the barrel) ,chamber was roughed , finish reamer used & stopped maybe 1/64 short...10 or so cases inserted in chamber & depth mike checked , .....longest was selected for h/space ga...dab of grease on piece of gillette blade added .003-.004,crush fit took away .0015 to .002,& you were left w/ .002 +/- hdspc.( for urself, ,probably left zero hdspc)...this worked well enuff ..if one case was tight , u pitched it , if too many , u put the t handle ext . on reamer & gave a twist....the one problem was the guy who bought his ammo, & needed a quick second shot ,with the old case jammed in chamber , or worse yet, the head torn off! but then again , any one hunting game that would just as soon track u ,& didnt run the cartridges thru the nite befor, is probably a candidate for the Darwin award, doing society a favor by removing himself from the human gene pool....noooowwww e. narramore ,recognizing th e fact that most everybody was poor,at that time, wrote his great book on handloading & the manufacture of ammo(principles of handloading?).....for rimmed h/space ga. it was pretty obvious before the book ....turn up a replica of the base of cartridge w/ rim thikness, the max cartridge drawing in loading h/book+ .002.....for rimless turn up a two diam. ga. , the base part about 1/4 in. + long ,atjust under the min. chamber spec ( h/book or other source)the front of the GA. is the x/act shoulder dim. at the datum line , total length is the max. cartridge drawing line from shldr datum to cartrdge base + .002 . if ur heavy handed in useing ga. ,u can roll the front edge,....if u harden ga. & are ham fisted , chamber will score .....but ,never to worry, himmel!, ve are gunschmitts, ya?...buchsenmachers!...und buchsenmeisters..!!!.........now if u realy want to make up a full shouldered one ,like the big boys do, ...clamp a sinbar on the compound, on its side ,w/ rolls facing towards end of bed, after eyeballing the compound in line w/crossfeed....grab an indicator in t/stock chuck & tap sinbar till it indicates SAME on both rolls as u crank it in /out ....now it is in same plane as compound,....next rotate compound so bar is near parallel w/ bed & rolls facing bed ( 1/4 turn left)...now grab an indicator in chuck & set compound to shldr angle by trigging out the difference in readings on two rolls .sin 1/2 shldr angle x inches between roll centers u now have correct angle to turn ga. also to MAKE A REAMER!!!(thank u d. johnson from keeping me from inadvertandly making wildcats by missing shldr angle...idea is not new, but he brought it to my attention!...if u had a proof bar & aligned centers, could instead,put ga. blocks between roll & bar to set the sin bar/compound...now is the tough part....one way to get length is turn up a short length of bar & bore a hole x/act shldr dim. at datum line ( usually 1/2 way down shldr,not always & 3006 on top edge of shldr,)..set a block/angle plate on surfaceplate/whatever,put a thick square against the angle plate (looks like a gallows)...put base of ga. under overhung square & slide down into hole in bar ...idea is to keep ga. plumb!...now measure from block to underside o f square ....note the difference from length on max cartrdg drawing & shorten ga correct amount .if ur really good ,u dont need to re check it ..har,har.....probably easiest to tslescope ga. the distance w/ ur third hand!!DONT use a dial caliper!......if u have a known correct chamber , just test ga. in rifle & & turn down till bolt closes!!...bit maybe if u already had that caliber ,u wouldnt be making another ...although many of the 06 family use the same ga.... when u come up w/ a simpler way to get correct length , i am all ears ,(at least the good left one)....what ? EAR protection!..nah!!!!
nice thing is ,engine on my 20 year old truck gets quieter every year!
best wishes
docn8as
best wishes
docn8as
