Othe uses for a Granite Surface Plate ?
  • Othe uses for a Granite Surface Plate ?
    Here's one:
    Why not save it for a marker on your
    eternal resting space.
    "Upon this rock he laid out the engine of his destruction."
    Pete
    1973 SB 10K .
    BenchMaster mill.
      Those you buy from Grizzly etc already are called "chinese tombstones".
      Although in truth, they are generally quite a bit better than that. At least I have two, and they blue up together just fine. Bought at different times, from different sources, and they are different sizes, so random, not related.
        Doorstep?
        -D
        DZER
          I picked up a 36x48x6 for a hundred dollar bill. I have no room in the shop so I use it as a prep table by the bar b que.
          996 pounds, It makes for a solid table.
            You can also do your marking out while eating a burger, is ketchup any good for marking out?
            I'm biased so it seems like a waste of table, you need a bigger shop!
            Mark
              Pete
              LOL - I like that...
              You could use it as a cool surface in the larder and forgo a refrigerator...
                Funny! I always suspected these things came from graveyards, others must have had the same idea. If you buy one, the text goes underneath.
                  I have one that is 96" x 48" x 10" thick that I purchased from work. It even came on a steel stand. I have said that it could be use to cover the entire casket and not just the tombstone. No one is going to remove it once it is on the ground. I think it weighs close to 4500 pounds. Sure make a good table to build stuff on.
