See: https://en.wikipedia.org/wiki/American_wire_gauge
Wire sizes and the corresponding numbered drill sizes make sense because a very wide range of commonly used sizes can be defined with just a single or two digit number. A #36 drill is defined as 0.005" or 5 mils. Every three wire sizes is double or half the cross-sectional area, which is useful for determining wire size according to current carrying capacity. So a #10 AWG is good for 30 amps, #13 is 15 amps, and #16 is 7.5 amps.
For wire, each increment of size corresponds to about 12% difference in diameter, For drills, each increment of size corresponds to about 1.5% to 5% difference in diameter, which is useful for making holes just a bit larger or smaller. It is not so obvious what the next standard metric size might be, although unlike number drill sizes, there is a formula.
From 0.2 through 0.98 mm, sizes are defined as follows, where N is an integer from 2 through 9:
From 1.0 through 2.95 mm, sizes are defined as follows, where N is an integer from 10 through 29:
From 3.0 through 13.9 mm, sizes are defined as follows, where N is an integer from 30 through 139:
From 14.0 through 25.0 mm, sizes are defined as follows, where M is an integer from 14 through 25:
- N · 0.1 mm
- N · 0.1 + 0.02 mm
- N · 0.1 + 0.05 mm
- N · 0.1 + 0.08 mm
- N · 0.1 mm
- N · 0.1 + 0.05 mm
- N · 0.1 mm
- M · 1 mm
- M · 1 + 0.25 mm
- M · 1 + 0.5 mm
- M · 1 + 0.75 mm
