Interesting find - What is it??
  • Interesting find - What is it??
    I picked this up from a closed aerospace machine shop.
    It's about 30" tall, with a dovetail and rack on the Z axis.
    It has two movable heads, each with what looks like a laser. These point at each other through the hole in the small table - which also moves.
    Brand is Cleveland, and it also is marked "Micro-Ac"
    I intend to repurpose it something different (Suggestions?), but before I reach the point of no return I'd like to know what it was used for. Anyone recognize it?
    looked like a hardness test, but then I saw laser, optic bench for lenses?
    Mark
      It's similar to a hardness tester, but the working tips are glass.
      A hardness tester usually has a hard point and an anvil. This has neither
      This shop made parts for Bell Helicopter. They had both manual and CNC machines.
        See your outher post.
          It's an 'opposed head comparator' originally designed for checking gauge blocks.
          Using two comparator heads (instead of a single one over a fixed surface) eliminates the need to wring the gauge block to the reference surface and reduces the potential for error.
          Cheers
            Barrington, that makes sense, thanks.
            The only question now is does it use lasers or just small camera lenses with the video fed to a PC?
              No, these aren't comparators in the sense of 'optical comparators', they're an electronic version of a very high resolution 'dial gauge'.
              A spring loaded plunger moves axially and it's position is determined electronically (usually electromagnetically via an arrangement of coils - Google "LVDT").
              With the opposed head type two transducer inputs are simply combined to show changes in the distance between the two tips.
              Cheers
              edit: Link to 'Handbook of Dimensional Measurement':- LINK
                I have not checked to see if the tips are spring-loaded, but they are glass.
                  I would use it to support a camera for taking pictures of flat things. books, art, things that don't scan well.
                    Actually, I have an ongoing project to do just that. I have already modified a Shadograph to mount a DSLR over a lightbox to photograph slides. Once finished I found I did not have a lens that would focus under 1 ft. This column gives me twice that focal distance, so it might work. GMTA
