I just had a wild idea. My shop is a two car garage, basically 20' x 20', so space is limited. For some time I have been thinking about getting a larger surface plate: I have a 9" x 12" now and that is only good for small parts. I do not have any good way for storing my 10" RT, it's tailstock, my angle plate, my milling vise, etc. So, I am wondering if I can kill two birds with one stone.
Make a steel (angle, channel) frame cart on large wheels for easy movement. Make a top that is at the same height as my mill table and mount it on two heavy duty bearings at the center of the long sides. Add tie downs for the various items to be stored there.
On the flip side of that top, make a mount for a new surface plate with the three point suspension. Again, add some clamps to hold the plate when it is flipped over.
The two ends would be open to allow the top to flip over with the various things on it.
Since the balance would not be exact, I would probably need some kind of braking and cranking mechanism to aid in turning it over. Perhaps a gear motor with a chain drive: I am lazy and too old to trust my muscles with that kind of weight. I can barely lift the RT now and have no idea if I can lift a new surface plate onto a table. A cord on a spring retractable reel to plug it in. Electrical interlocks on those clamps to prevent dumping them. And lock-downs for the table at each end of rotation, also interlocked.
I may need a bridge piece to aid in sliding the mill items back and forth. Or perhaps a small crane with stabilizing legs below that extend under the mill table.
I may have to learn welding for this. I need/want to anyway. I think I am going to look up the weights of some surface plates.
Your thoughts? Am I crazy? Great idea? Or what?
