Having built about a dozen model internal combustion engines, I have decided to write down everything I know about building and running these engines as a guide to others who want to build one.
I’m not talking about high revving two cycle screamers here, not compression/ignition engines. Just plain old four cycle petrol fueled spark ignition engines, similar to the Webster or the Kerzel hit and miss engine.
It makes no difference if they are air cooled or water cooled, all of the following advice is relevant, with one caveat.—If the engine is air cooled and NOT running a propeller, it is probably going to overheat without some kind of auxiliary cooling fan after about 15 minutes running. A water cooled engine with a reservoir of water around the cylinder will run much, much longer without overheating.
These engines are built primarily from 6061 aluminum, with a cast iron cylinder liner (or the entire cylinder built from cast iron.) The crankshaft is generally made from mild steel, either machined from solid stock or “built up” from a number of pieces soldered or press fitted together. If machined from solid, 1144 stress-proof steel is highly recommended, because it doesn’t tend to deform from internal stresses during the machining operation.
