"Tessy" only the beginning
This topic is closed.
Yeah, you'd have to call it a screw up, but OTOH the computer is never drunk, coked up, yakking on the phone, putting on lipstick or eating a burger while it drives..
They said the truck was hard to see because it was light colored against a similar color sky. Add a little glare and isn't that the same reason people run into trucks?
Most of the cars with autopilot use radar as well as visible light to map out their surroundings.
DanAt the end of the project, there is a profound difference between spare parts and left over parts.
Originally posted by danlb View PostThey said the truck was hard to see because it was light colored against a similar color sky.
There is no possible way the truck was lit just right as to appear invisible to anyone that was even paying a minimal amount of attention.
Add that to the fact the car, as I understand it, looks for objects at about waist height and below for collision avoidance, as the truck was straddling the lane, the car essentially didn't "see" it.
Tragic, yes. But a rare and unlikely set of conditions, with the end result entirely the fault of the driver. The "auto pilot" is just a fancy cruise control, not a "set it and head into the back to make a sandwich" thing.
Doc.Doc's Machine. (Probably not what you expect.)
Originally posted by TGTool View PostYeah, you'd have to call it a screw up, but OTOH the computer is never drunk, coked up, yakking on the phone, putting on lipstick or eating a burger while it drives.
If you're drunk in an auto-piloted vehicle, is it still drunk driving?
The autopilot in an airplane is a useful aid and has NEVER assumed the role of PILOT IN COMMAND. The autoassist in the vehicle is the same. It was missused by the driver. The driver is soley at fault.
Just Darwin thinning the gene pool of idiots.Last edited by SpoonerandForker; 07-01-2016, 08:14 AM.I hear and I forget.
I see and I remember.
I do and I understand.
Confucius (孔夫子)
Originally posted by RB211 View PostAutopilots on airliners mess up all the time, and its much simpler environment to design a system for.George
Traverse City, MI
Originally posted by SpoonerandForker View PostThe autopilot in an airplane is a useful aid and has NEVER assumed the role of PILOT IN COMMAND. The autoassist in the vehicle is the same. It was missused by the driver. The driver is soley at fault.
try being a motorcycle rider and "making eye contact" with that one at an intersection...
Originally posted by George Bulliss View PostSimpler environment, plus decades of development and a systems price that is probably over the cost of most new cars and you still need trained professionals to monitor and take over when needed. One of the reasons I've been skeptical of all the hype for driver-less cars.
If you removed the costs for liability insurance, remove lawyers from the equation, and FAA certification, then your probably looking at 50 to 100k for the cost.
Everything in aviation is leased. Every component on the airplane is modular, almost everything in the cockpit is "plug and play." When a switch fails on a radio, the entire radio panel comes out, gets sent out for refurbishment, and a new one is plugged in. However, if the trim switch on the yoke fails, then you'll see the mechanic having to hand solder in a new one, the switch is glued into the yoke, and yoke doesn't simply come out.
From what I can see on an airliner, it appears that the autopilot system on the CRJ that I fly is mostly just cascading PID algorithms. The inputs to the algorithms are simple data streams. Vertical velocity, G forces, headings, tracks, GPS track, Altitude, airspeed, etc.
On a car, your dealing with a few magnitudes more complexity, your using artificial vision to decipher where you are on the road. The algorithms involved for that are simply mind boggling. How can the car autopilot be programmed for every single situation that arrises? IT CANNOT. Something that is NOT typical, like in this fatal accident with the truck. The truck was not where it was supposed to be, bright sun and truck color combination made it hard for the artificial vision to decipher what it was. Self driving cars are a joke, not until every single road in this country is setup like a slot car track.
Originally posted by Doc Nickel View Post- The "auto pilot" is just a fancy cruise control, not a "set it and head into the back to make a sandwich" thing.
Doc.Weston Bye - Author, The Mechatronist column, Digital Machinist magazine
When that happens, the best case scenario is that the vehicle just refuses to move. And that is not a particularly good scenario in most cases.
Remember, there are many road situations where a person is puzzled as to where to go. Program for that one?
And, think about the opportunities for gridlock with a horde of these vehicles. Somehow they have to co-ordinate and find the best overall solution FOR THAT PARTICULAR ROAD CONFIGURATION AND SET OF VEHICLE POSITIONS. Goof luck with that. It's possible, but NOT likely as autonomous vehicles.
The entire idea is, for the moment, hubris. Dunno that I want to be on the road with these things. Certainly not wanting to be an early adopter on them.
As a centrally controlled system? Sure. MUCH easier. And that will probably be the endpoint on it..... The city traffic computer tells your vehicle what to do, when to do it, and can send you back home if traffic is too tight.CNC machines only go through the motions.
Originally posted by J Tiers View PostAs a centrally controlled system? Sure. MUCH easier. And that will probably be the endpoint on it..... The city traffic computer tells your vehicle what to do, when to do it, and can send you back home if traffic is too tight.
