Morse Taper Reamer's
  • #16
    Originally posted by boslab View Post
    Somthing I saw once, it was a brass I think, or possibly phos bronze plug, MT, it had a slot in it and a 1/4" slip stone was in the slot, loose, there were a couple of springs to push the stone, I would assume the plug be stuck in the hole and rotated, it was home made but looked well done, similar idea to a sunnen hone, I often thought about making one to clean my tailstock which is a bit gnarly, just an idea
    the problem with using abrasives of that sort in taper of course is that there is no axial movement between work and cutting tool. If you held a sunnun in exactly the same spot you would likely not get an accurate result. This is why you need an internal grinder or as Jerry suggests a hand held stone. Without something with axial movement, the big burr quickly/instantly goes through the sandpaper or chips the stone away, fixing of the problem promptly stops while uncontrolled material removal from other place continues. Taken to the extreme, the whole taper could end up like a stack of rings. A reamer otoh, if it can cut, doesn't change shape so avoids this.
    • #17
      A reamer can be forced to the side as it cuts the burr, so it can slightly egg the gtapered hole. If you can guide the reamer accurately down center, and feed it slowly so it can only cut high spots, it will work, though.
      The best thing to do other than re-grinding is to attack the individual issues, if possible, with hand held stones. Low spots do not matter much, but anything that sticks up is bad. Or bore the taper and then either grind or ream, so that you are cleaning up a basically accurate hole. Not always possible to do the latter things in the home shop.
      • #18
        One thing to consider not doing is using home made Morse tapers in a good quill. It's quite difficult on home shop machines to turn accurate Morse tapers.
        Okay, fire way. Let's hear all your stores about turning accurate Morse tapers. But, I won't believe a single one.
        • #19
          It might be quite difficult BUT...after seeing some of the work done by some of the members here, I have absolutely no doubt that they can turn an accurate taper.
          • #20
            So why would it be more or less difficult to accomplish this in a home shop environment? Many members here have world class machine tools capable of duplicating work and products that would be available anywhere else.
            Among many advantages, a DRO really makes turning accurate tapers much more of a walk in the park as opposed to a polar expedition. Using the DRO to set a taper attachment allows a person to generate a theoretically perfect taper as opposed to attempting to mount a sample arbor concentrically and then running back and forth with an indicator to achieve the proper angle.
            It can be done without a pattern using some long range dial indicators, but fiddling with multiple indicators and attempting to remember which direction the backlash should go can lead to altered states of consciousness and promote the development of anti-social rhetoric.
            • #21
              he's wrong about turning accurate morse tapers, a common enough machinists task. All that is needed is a decent lathe with taper attachment. For those not familiar, you check a taper on a sine bar on a plate with an indicator. Getting a taper dead on is a matter of iterations of tweaking the taper attachment, all with the work between centres.
              Making a reamer adds complexity - high treating and grinding. set up a master on a T&CG, and indicate it to zero while swiveling the table. The only part that isn't believable about someone making one, is why they'd bother. I've enough stuff to make one but, its such an effort i can't imagine doing so vs the cost of buying one.
              • #22
                " Okay, fire way. Let's hear all your stores about turning accurate Morse tapers. But, I won't believe a single one. "
                Okay, no stories then.
                Don't need a Monarch, don't need a DRO.
                Morse tooling is a cakewalk compared to a tapered journal 24" OD with a liquid nitrogen shrink fit $10grand bearing done an old lathe.
                Not like you can take it off centers and blue multiple times.
                • #23
                  I have a live center that i made from scratch years ago, with a # 2 morse taper shank i use it when ever a need a live center the MT is accurate and seats perfect. I machined it on a South Bend Lathe there is no problem turning MT on any lathe
                  • #24
                    A few years back, I recall a company advertising a taper socket cleaner/refurbisher. I THINK that it was a hard urethane with very fine abrasive embeded. They offered all common Morse tapers. Anybody recall the name?
                    Duffy, Gatineau, Quebec
                    • #25
                      My opinion never use any abrasive object or tool to clean up a MT. MT reamers are made for that
                      • #26
                        Stories? Whatever.
                        I can and do turn MT shanks for tooling. It's a bit fussy to do, but most things that you want accurate are like that. No idea why you would consider it difficult or, as it seems, impossible.
                        Arbor with turned taper
                        Some more
                        Really?
                        I guess you DO realize that the tapers were ground with abrasives to begin with..... Unless they are in one of the cheapest asian products. I DID see a drill press that had a turned socket,it was as rough as a cob, they never ground that one, just roughed it.
