I want to turn a semicircular cross-section groove in the face of a washer made of 6061-T6 aluminum. The OD of the groove is 2". The washer (disc?) will be held in a 3-jaw chuck with accurately bored soft jaws on a 14x40" lathe. My plan is to grind a tool bit of the right profile and plunge cut after trepanning out a lot of the material first.
I don't have access to an optical comparator, just a set of radius gages. I don't have much confidence in my ability to grind a tool bit to a semicircular profile with any degree of accuracy. I don't think I have any that will work in my junk box of HSS lathe toolbits (don't we all have such a junk box?).
How would you do this grind?
metalmagpie
metalmagpie
