Two ways to balance a grinding wheel
  • justanengineer
    JME but the problem I see most often with bench grinders is that folks buy a lightweight cheapie. Many folks run the grinder without the wheels, see it run smooth, and assume the problem must be the wheels so they dink around trying to balance good wheels. In reality the problem is the grinder itself, the effect is simply magnified by the added mass of the wheels. I usually suggest folks either build a solid base to add damping or spend $10 on a vintage grinder as theyre quite a bit heavier, much better solutions IMHO.
  • enginuity
    So, neither static balancing or dressing will not get it dead on because of clearance....for that you'd need dynamic balancing. However, I wouldn't bother. Static balancing and dressing will go a long way towards solving most of the problem....and after all, its bench grinder.
    I agree that static balancing works - I statically balance the wheels I use on the surface grinder at work once they are mounted on the hub. The bench grinder I find to be a bit more involved in that you need to mount the wheels on some sort of arbor and statically balance the wheel itself and then move it to the bench grinder - which leaves a lot of room for error. I think if you had a high quality bench grinder it would be pretty close once you dressed it. Statically balancing while the wheels are mounted on the grinder is hopeless.
    I have an import bench grinder from Home Depot. I think (now at this point I'm hypothesizing - I haven't actually checked) that there is much to be desired in out of the box state of many import bench grinders. I really don't think the manufactures balances them. This I think is the problem with a lot of bench grinders. Yes the wheel can be out of balance, but so too can the grinder itself. The reason nobody cares is because most bench grinders are purchased to mount a wire wheel on one side and sharpen law mower blades on the other. Only the machinists and elite woodworkers want a really nicely balanced setup.
    Very interesting read. I learn every day.
    They have a pretty goot lever arm from wheel to wheel, so trying to balance both from one end sounds like a bad idea... the thing will try to walk away if the balance isn't at least decent at each wheel. Static balance will be fine at each, but naturally best if it can be done with the wheel on the grinder. Usually that is not possible due to friction, so you end up static balancing the wheel e;elsewhere and hoping it's OK, which it often will be..
  • Mcgyver
    Originally posted by metalmagpie View Post
    Over the years I've seen several articles that present solutions to the problem of how to balance a grinding wheel on a bench grinder. I ran into this problem recently and found a couple of solutions. See what you think. - metalmagpie
    http://www.nwnative.us/Grant/shop%20...able/balancing
    I see says the idea came from a thread i posted in 2005 (he gives the link).
    Learned a thing or two since then. While the idea works, 11 years later i'd reflect that it, and what he's doing is just over complicating things, esp for a bench grinder. Instead, with a balancing rig, just rub off a bit the grinding wheel material on the side corner with a carborumdum dressing stick. Gets the same result, easy and fast.
    Grinding wheels have some clearance on the shaft both for installation and for safety. The rotor (and therefor shaft) is going to warm faster than the wheel and radial pressure in the ID of the wheel from an expanding shaft is to be avoided.
    semi ot; Surface grinders avoid this with wheel hubs. You leave on the wheel and have a taper mount system for fixing them to the shaft. (but you still want a soft start/stop because the jerk on starting can shift the wheel slightly undoing all the careful balancing). There's a crowd that will say you don't need to balance surface grinding wheels; these people see the world through their commercial experience and within that they're right....however on light grinders likely to be seen in the home the perfect finish is slightly elusive and balanced wheels make a difference.
    No, because the two wheels, even if static balanced at one end, may still have different imbalances. They ADD UP TO what you correct with at one end, but the one at the far end still has a vibration that tends to make that end rotate off-center even of the first end were correct, which it won;t be. The end with the balance weight will be overbalanced, the end without underbalanced.
  • Davidhcnc
    Mag, That is a good read and thank you for taking the time to present.
    I have a question, on a standard bench grinder with two wheels,
    If you install the self balancing washer on one wheel will this correct the balance of the whole system?
    Originally posted by J Harp View Post
    For safety shouldn't you put a larger washer with relieved center against the wheel, and put the teardrop washers outboard of that?
    Likely so.....
  • J Harp
    Originally posted by DR View Post
    Since I didn't see mention of it, did you dress the wheels before balancing? In theory, that should at least make them concentric with the center hole.
    Maybe.
    Wheels need a little clearance around the hub, both so they can slide on, and so they are not being forced and stressed radially. That means they can be mounted slightly off-center, and that also the balance can therefore be different on the grinder from on the balancer, unless you have a tapered hub that stays on the wheel and mounts consistently on the spindle.
    Dressing SHOULD just remove material of even density all around. If so it won't change the balance of a previously balanced wheel that has not been re-mounted. But if balanced in one position vs center, then re-mounted and dressed, the previous balance may not be valid, and removed material may not result in a concentric surface, changing the basic balance of the wheel.
    How much effect there can be from the mounting depends on how much clearance there is from wheel to hub, and hub to spindle.
  • metalmagpie
    Originally posted by enginuity View Post
    Why didn't you mount your cell phone on there and quantify the results .
    I did install Accelerometer Meter on my Android phone. I tried just holding it against the grinder body. I got readings, but at the time didn't really understand what I was seeing. The metric I was interested in optimizing was the finish on the drills and lathe tools I ground anyway. I like numbers and might go back and measure some data someday. But you can just as easily put a tuna can full of water on the grinder table and look at the pattern on its surface. That's a pretty revealing test, actually.
    metalmagpie
  • metalmagpie
    I did true the blue CGW wheel before balancing. It was the one that had the most imbalance. Dressing it true didn't help the balance that I could detect.
    metalmagpie
  • SpoonerandForker
    It is interesting how little weight at a small distance from the center of rotation will balance these wheels.
    Thanks for the education.
  • DR
  • enginuity
    Great job and I'm going to make some washers as well I think.
    Thanks for posting - so many people use bench grinders and pull their hair out trying to balance it and then move to using belt sanders. I was in the same boat until my bench grinder was balanced. I use my bench grinder a lot more now.
