1) How do you establish the relationship between the cutter and the work? Do you have to "just touch" the work with the cutter and hit a zero button? In all 3 planes (on a miller, 2 on a lathe)? Every time you change cutters?
2) Am I right that CNC lathes can cut threads without using a gear train to control the leadscrew? If so, and the leadscrew is controlled by a stepper or servo motor, how do the electronics calculate how to move the motor? I'm assuming there is some type of encoder on the spindle that generates, say, 1024 pulses per spindle rotation. But no matter what the number of pulses per revolution, most screw pitches won't divide into it evenly. Seems as if it would take some fancy footwork to avoid pitch errors, especially if you have to calculate all this stuff while the spindle is turning. Or is there some simple method I have missed?
